Difference Between Value Contract And Scheduling Agreements In Sap
-April 8, 2021-
As a general rule, the objective of framework agreements is to set a ceiling or a total volume (i.e. a target value). For quantity contracts that are very specific to individual materials and therefore often related to a material number (field: EKPO_MATNR), because the number of parts or the number of parts play an important role here (although there are other possibilities. B for an unknown material or consumables that I will not study here). This is why the target value here is at the level of the respective contract position, since the target quantity (field: EKPO_KTMNG) multiplied by the price of the material in question gives the reference value (field: EKPO_ZWERT) of each item. A contract is a long-term framework agreement between a lender and a customer via pre-defined equipment or service over a period of time. There are two types of contracts - in the left tree you will have details on the contract and the delivery plan. The above voucher categories are assigned as attributes to each purchase proof in the EKKO head data table (field: EKKO_BSTYP). This means that the document category allows us to distinguish delivery plans from other contracts. But how do you distinguish value contracts from volume contracts? This is where the storm table described above comes in: in the standard, the type of contract "MK" is for volume contracts and "WK" for value contracts. However, both types of documents have the same category of "K" document. While document categories are primarily used for categorization, document types are often used to customize, i.e. attributes are assigned to document types, which are then used to organize the process/control process in a system.
You can also be in the EKKO table, the field name is EKKO_BSART. The terms of a framework agreement apply up to a specified period of time and cover a certain pre-defined amount or value. Now it`s becoming exciting (at least for data analysts): framework agreements such as quantity contracts, value contracts and delivery plans are not stored in their own tables, but also in the EKKO and EKPO tables. So don`t get confused by names or take them too literally. Step-2 Enter the contract`s end date in the head data screen. Futures agreements, on the other hand, are based more on quantities and, in addition, on concrete quantities of delivery on certain delivery dates (we are talking about dates). Quite simply, these are more restrictive quantitative contracts - but in the analysis of the data in SAP® they appear separately with their own category of supporting documents in relation to volume or value contracts. But later. You can clearly display the category (K or L) and the type of document associated (LP, WK, MK). Our system includes 154 agreements. A contract may not be a bad option for materials purchased with a frequency of a week or more.
