Hey guys,
Up for sale is my 2000 BMW 328Ci. She has 203k miles currently. 5 speed manual. Clutch was replaced at 130k miles. I've had the car for 2 years. Just ready for something else. 5200 OBO. No trades. Feel free to call or text me. 925-286-8477. Car is located in Las Vegas, NV.
All Maintence is up to date. Car has no leaks. I have done all the work myself since I am dealer trained BMW technician. I have some extra parts that I will include with the car. Compression and leakage test were performed at 192k miles. Compression was 170psi across the board. With the max leakage at 9%. BMW spec for new motors is 8% leakage. Car still has tons of life left.
Modifications:
Broadway static coilovers ($1400)
Full M3 interior in Dove Grey ($1200)
Custom exhaust
G-power wheels($900)
LED tail lights, side markers, clear corners ($400)
Polyurethane lower control arm bushings ($100)
All work performed in the last 60k miles:
Oil changes every 5k
Full cooling system refresh (water pump, hoses, thermostat, radiator, expansion tank)
Coolant flush
Oil pan gasket
Rear diff bushing
Pinion seal on diff
Diff fluid change
Air filter
Microfilter
Valve cover gasket
New alternator
New battery
New center support bearing
New motor mounts
What the car needs:
Passenger door lock actuator. (Passenger door only works from inside)
Brakes front and rear (might be replacing soon)
Windshield is cracked on the bottom right (hardly noticeable)
Instrument cluster (speedometer stopped working)
Modifications:
Custom exhaust
Coolant flush
Oil pan gasket
Rear diff bushing
Pinion seal on diff
Diff fluid change
Air filter
Microfilter
Valve cover gasket
New alternator
New battery
New motor mounts
What the car needs:
