Originally posted by Zic
View Post
Wheel fitment, could use advice from e30 owners
Originally posted by Average_Jerk View Postdunno guys, im just not a huge fan of the way 18s look on the e30
16''/17'' are awesome, 18'' can be pulled off.-Instagram@jdjurhuus
Stretchsaurus and Pokemon.
WTF? 15's aren't too small for e30's. I've run both 15's and 16's and I definitely like how the 15" way better.
But if you go 16's, do 9" et10 and 10" et10. Go lower offset if you want more poke. Oh and 215/40's all around would be the bees knee's.
Originally posted by Oscar View PostWTF? 15's aren't too small for e30's. I've run both 15's and 16's and I definitely like how the 15" way better.
Average_Jerk, i think type A's are the right choiceand they are also WAY cheaper then $3440
Type As are ok but they are very heavy, and offer almost no brake clearance. I am a big fan of 16"s on e30s as they are potentially light enough to not toss the unsprung weight goal out the window. A good set of 15"s can be pulled off and shave quite a bit of weight as well while being reasonably easy on the wallet.
Erik
Originally posted by Stephen View Post15s and 18s take some work to do up proper, but can look good. 16 is probably the most common size for agressive fitment. In comparison though, 17s really fill the wheel wells, but take some more work to fit and are slightly less common in the "aggressive fitment" world
Originally posted by 610EURO View Postdo you have a pic of a nice of 15" wheels that dont look horribly small ?
Originally posted by two240s View Postwith a 9 in the front, anything higher than et12 will hit the strut.
13mm spacer in front. 25mm in rear.
from what ive seen the 25mm spacer on a 16x9 +25 in the read sounds right, but as far as the front, will a 13-15mm spacer flush the wheel?
edit - theres a pic on the first page 15x9 +1. it poke more than i want. so maybe a 13-15mm spacer would be right. that would make the offset +10ish. now that im home from work i can actually think a little better lolLast edited by Average_Jerk; 04-06-2010, 07:33 PM.
I ran 16x9 +5, it was flush with 215/40 that didn't stretch much at all, looked more like 225/40. +5 is where you want the front with 215's and camber plates. You could even do +0 with 205's. The rear definitely needs to be at least a 20-25mm spacer with a 215 or smaller, but of course you can get bigger spacers.
But why get wheels that need spacers if you were going to get custom wheels the first time around?
